Feed SDK下载和过滤Feed文件
消耗积分:0 | 格式:zip | 大小:0.04 MB | 2022-05-27
李鑫
分享资料个
授权协议 Apache 2.0
开发语言 Python
操作系统 跨平台
软件类型 开源软件
所属分类 应用工具下载工具
软件简介
Feed SDK 是 eBay 开源的 Python 开发包,用于下载和过滤通过公共 Feed API 提供的大型项目 Feed 文件。
用法
使用命令行选项
可以使用命令行调用 SDK 的所有功能。
要查看可用选项和过滤器,请使用 '--help'
usage: FeedSDK [-h] [-dt DT] -c1 C1 [-scope {ALL_ACTIVE,NEWLY_LISTED}]
               [-mkt MKT] [-token TOKEN] [-env {SANDBOX,PRODUCTION}]
               [-lf LF [LF ...]] [-sellerf SELLERF [SELLERF ...]]
               [-locf LOCF [LOCF ...]] [-pricelf PRICELF] [-priceuf PRICEUF]
               [-epidf EPIDF [EPIDF ...]] [-iepidf IEPIDF [IEPIDF ...]]
               [-gtinf GTINF [GTINF ...]] [-itemf ITEMF [ITEMF ...]]
               [-dl DOWNLOADLOCATION] [--filteronly] [-format FORMAT] [-qf QF]
Feed SDK CLI
optional arguments:
  -h, --help            show this help message and exit
  -dt DT                the date when feed file was generated
  -c1 C1                the l1 category id of the feed file
                        the feed scope. Available scopes are ALL_ACTIVE or
                        NEWLY_LISTED
  -mkt MKT              the marketplace id for which feed is being requested.
                        For example - EBAY_US
  -token TOKEN          the oauth token for the consumer. Omit the word
                        'Bearer'
                        environment type. Supported Environments are SANDBOX
                        and PRODUCTION
  -lf LF [LF ...]       list of leaf categories which are used to filter the
                        feed
                        list of seller names which are used to filter the feed
                        list of item locations which are used to filter the
                        feed
  -pricelf PRICELF      lower limit of the price range for items in the feed
  -priceuf PRICEUF      upper limit of the price range for items in the feed
                        list of epids which are used to filter the feed
                        list of inferred epids which are used to filter the
                        feed
                        list of gtins which are used to filter the feed
                        list of item IDs which are used to filter the feed
  -dl DOWNLOADLOCATION, --downloadlocation DOWNLOADLOCATION
                        override for changing the directory where files are
                        downloaded
  --filteronly          filter the feed file that already exists in the
                        default path or the path specified by -dl,
                        --downloadlocation option. If --filteronly option is
                        not specified, the feed file will be downloaded again
  -format FORMAT        feed and filter file format. Default is gzip
  -qf QF                any other query to filter the feed file. See Python
                        dataframe query format
例如,使用命令行选项使用令牌下载和过滤 Feed 文件
python feed_cli.py -c1 3252 -scope ALL_ACTIVE -mkt EBAY_DE -env PRODUCTION -qf "AvailabilityThreshold=10" -locf IT GB -dl DIR -token xxx
过滤 Feed 文件,不需要令牌
python feed_cli.py --filteronly -c1 260 -pricelf 5 -priceuf 20 -dl FILE_PATH
评论(0)
发评论
下载排行榜
