最全的贴片二极管型号查询
消耗积分:10 | 格式:exe | 大小:3 MB | 2011-01-14
分享资料个
贴片二极管对照表:这本书的目的是提供一个简单的方法的设备鉴定。它列出了超过3400个二极管型号,介绍了二极管的型号、封装及参数功能。
Code Device Manufacturer Base Package Leaded Equivalent/Data
0 2SC3603 Nec CX SOT173 Npn RF fT 7GHz
005 SSTPAD5 Sil J - PAD-5 5pA leakage diode
p01 PDTA143ET Phi N SOT23 pnp dtr 4k7+4k7
t01 PDTA143ET Phi N SOT23 pnp dtr 4k7+4k7
01 Gali-1 MC AZ SOT89 DC-8GHz MMIC amp 12dB gain
010 SSTPAD10 Sil J - PAD-10 10pA leakage diode
011 SO2369R SGS R SOT23R 2N2369
02 BST82 Phi M - n-ch mosfet 80V 175mA
02 MRF5711L Mot X SOT143 npn RF MRF571
02 DTCC114T Roh N - 50V 100mA npn sw + 10k base res
02 Gali-2 MC AZ SOT89 DC-8GHz MMIC amp 16dB gain
p02 PDTC143ET Phi N SOT23 npn 4k7+4k7 bias res
t02 PDTC143ET Phi N SOT23 npn 4k7+4k7 bias res
03 Gali-3 MC AZ SOT89 DC-3GHz MMIC amp 22dB gain
03 DTC143TE Roh N EMT3 npn dtr R1 4k7 50V 100mA
03 DTC143TUA Roh N SC70 npn dtr R1 4k7 50V 100mA
03 DTC143TKA Roh N SC59 npn dtr R1 4k7 50V 100mA
04 DTC114TCA Roh N SOT23 npn dtr R1 10k 50V 100mA
04 DTC114TE Roh N EMT3 npn dtr R1 10k 50V 100mA
04 DTC114TUA Roh N SC70 npn dtr R1 10k 50V 100mA
04 DTC114TKA Roh N SC59 npn dtr R1 10k 50V 100mA
04 MRF5211L Mot X SOT143 pnp RF MRF521
04 Gali-4 MC AZ SOT89 DC-4GHz MMIC amp 17.5 dBm
-04 PMSS3904 Phi N SOT323 2N3904
t04 PMBS3904 Phi N SOT23 2N3904
05 Gali-4 MC AZ SOT89 DC-4GHz MMIC amp 18 dBm o/p
05 DTC124TE Roh N EMT3 npn dtr R1 22k 50V 100mA
05 DTC124TUA Roh N SC70 npn dtr R1 22k 50V 100mA
05 DTC124TKA Roh N SC59 npn dtr R1 22k 50V 100mA
05F TSDF1205R Tfk WQ - fT12GHz npn 4V 5mA
06 Gali-6 MC AZ SOT89 DC-4GHz MMIC amp 115 dBm o/p
06 DTC144TE Roh N EMT3 npn dtr R1 47k 50V 100mA
06 DTC144TUA Roh N SC70 npn dtr R1 47k 50V 100mA
06 DTC144TKA Roh N SC59 npn dtr R1 47k 50V 100mA
-06 PMSS3906 Phi N SOT323 2N3906
t06 PMBS3906 Phi N SOT23 2N3906
020 SSTPAD20 Sil J - PAD-20 20pA leakage diode
050 SSTPAD50 Sil J - PAD-50 50pA leakage diode
081 SO2369AR SGS R SOT23R 2N2369A
09 DTC115TUA Roh N SC70 npn dtr R2 100k 50V 100mA
09 DTC115TKA Roh N SC59 npn dtr R2 100k 50V 100mA
0A MUN5111DW1 Mot DO SOT363 dual pnp dtr 10k+10k
0A DTC125TUA Roh N SC70 npn dtr R2 100k 50V 100mA
0A DTC125TKA Roh N SC59 npn dtr R2 100k 50V 100mA
0B MUN5112DW1 Mot DO SOT363 dual pnp dtr 22k+22k
0C MUN5113DW1 Mot DO SOT363 dual pnp dtr 47k+47k
0D MUN5114DW1 Mot DO SOT363 dual pnp dtr 10k+47k
0E MUN5115DW1 Mot DO SOT363 dual pnp dtr R1 10k
0F MUN5116DW1 Mot DO SOT363 dual pnp dtr R1 4k7
0G MUN5130DW1 Mot DO SOT363 dual pnp dtr 1k0+1k0
0H MUN5131DW1 Mot DO SOT363 dual pnp dtr 2k2+2k2
0J MUN5132DW1 Mot DO SOT363 dual pnp dtr 4k7+4k7
0K MUN5133DW1 Mot DO SOT363 dual pnp dtr 4k7+47k
0L MUN5134DW1 Mot DO SOT363 dual pnp dtr 22k+47k
0M MUN5135DW1 Mot DO SOT363 dual pnp dtr 2k2+47k
评论(51)
发评论
拓扑扑 2022-07-03
0 回复 举报
正好需要 收起回复
harveyhao 2021-10-27
0 回复 举报
收起回复
全部评论
下载排行榜
全部51条评论
