LeanClub 是高性能 C++ 论坛系统。
注意:不建议在生产环境使用!
特性
速度非常快,20000 RPS on i7 iMac.
前端非常简洁
完全是 Ajax 和 API
可以使用 Google GitHub Twitter OAuth 登录
要求
GCC 4.8
CMake 2.8
(不支持 Windows)
安装
数据库
创建 4 个数据库: “category” “notification” “topics” 和 “user”
导入 “databases” 目录
环境
apt-get install build-essential cmake libcurl4-nss-dev libboost-all-dev redis-server libtcmalloc-minimal4 && sudo ln -s /usr/lib/libtcmalloc_minimal.so.4 /usr/lib/libtcmalloc_minimal.so -
Install hiredis from sources ( redis3m is already included )
配置
cp src/config.h.example.h src/config.h vi src/config.h
构建运行
mkdir Build cd Build cmake .. make ./leanclub
Nginx
server {
listen 80;
server_name leanclub.org;
client_max_body_size MAX_UPLOAD_SIZE;
root /path/to/leanclub/;
location / {
proxy_pass http://127.0.0.1:18080;
proxy_redirect off;
proxy_set_header X-Forwarded-For $http_x_forwarded_for;
proxy_set_header Host leanclub.org;
add_header X-XSS-Protection "1; mode=block";
add_header X-Frame-Options DENY;
# Cache the avatar (Optional)
# location /info/ {
# proxy_pass http://127.0.0.1:18080;
# proxy_redirect off;
# proxy_set_header X-Forwarded-For $http_x_forwarded_for;
# proxy_set_header Host leanclub.org;
# proxy_cache one;
# proxy_cache_key "$request_uri";
# proxy_cache_valid 200 302 120m;
location /static/ {
expires 10d;
location /attachments/ {
expires 365d;
reverse proxy 127.0.0.1:18080 , and map the "static" and "attachments" folder.
关于
此系统基于 Crow
