Arduino UNO液晶屏开源
消耗积分:2 | 格式:zip | 大小:0.01 MB | 2022-08-12
而无返还
分享资料个
电路板图如下:
成分
ARDUINO UNO REV3 × 1
通用 220 欧姆电阻器 × 1
LCM-S01602DSF/A
Lumex 光电/组件公司
× 1
Arduino UNO 液晶屏
建造盾牌:
组装:
盾构图如下:
LCD RS 引脚到数字引脚 12
LCD 使能引脚到数字引脚 11
LCD D4 引脚到数字引脚 5
LCD D5 引脚到数字引脚 4
LCD D6 引脚到数字引脚 3
LCD D7 引脚到数字引脚 2
LCD R/W 引脚到 GND
LCD VSS 引脚至 GND
LCD VCC 引脚至 5V
LCD LED+ 通过 220 欧姆电阻器至 5V
LCD LED- 到 GND
电阻器进入电阻器符号。每个孔中都有焊针。就是这样!
使用盾牌:
要使用显示器,您必须在 Arduino IDE 上安装 LiquidCrystalDisplay 库。
我将在下面留下一个 Hello world 示例来使用显示器。;)
代码
你好世界!
阿杜诺
  LiquidCrystal Library - Hello World
  Demonstrates the use a 16x2 LCD display.The LiquidCrystal
  library works with all LCD displays that are compatible with the
  Hitachi HD44780 driver. There are many of them out there, and you
  can usually tell them by the 16-pin interface.
  This sketch prints "Hello World!" to the LCD
  and shows the time.
  The circuit:
  * LCD RS pin to digital pin 12
  * LCD Enable pin to digital pin 11
  * LCD D4 pin to digital pin 5
  * LCD D5 pin to digital pin 4
  * LCD D6 pin to digital pin 3
  * LCD D7 pin to digital pin 2
  * LCD R/W pin to ground
  * LCD VSS pin to ground
  * LCD VCC pin to 5V
  * 10K resistor:
  * ends to +5V and ground
  * wiper to LCD VO pin (pin 3)
  Library originally added 18 Apr 2008
  by David A. Mellis
  library modified 5 Jul 2009
  by Limor Fried (http://www.ladyada.net)
  example added 9 Jul 2009
  by Tom Igoe
  modified 22 Nov 2010
  by Tom Igoe
  modified 7 Nov 2016
  by Arturo Guadalupi
  This example code is in the public domain.
  http://www.arduino.cc/en/Tutorial/LiquidCrystalHelloWorld
  // include the library code:
  #include
  // initialize the library by associating any needed LCD interface pin
  // with the arduino pin number it is connected to
  const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
  LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
  void setup() {
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("hello, world!");
  void loop() {
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 1);
  // print the number of seconds since reset:
  lcd.print(millis() / 1000);
评论(0)
发评论
下载排行榜
