MIC2605/MIC2606 Evaluation Boa
消耗积分:5 | 格式:rar | 大小:333 | 2009-03-19
分享资料个
The MIC2605/6 is a 1.2MHz/2MHz, PWM DC/DC boost
switching regulator available in a 2mm x 2mm MLF®
package. High power density is achieved with the
MIC2605/6 internal 40V/0.5A switch and 1Ω schottky
diode, allowing it to power large loads in a tiny footprint.
Requirements
The MIC2605/6 evaluation board requires an input power
source that is able to deliver greater than 500mA at 4.5V.
Precautions
The evaluation board does not have reverse polarity
protection. Applying a negative voltage to the VIN (J1)
terminal may damage the device.
The MIC2605/6 evaluation board is tailored for a 4.5V to
20V input voltage range. The input voltage range should
not exceed 20VDC on the input.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
