51单片机控制nrf401 C语言源程序
消耗积分:10 | 格式:rar | 大小:8 KB | 2011-03-14
王兰
分享资料个
#ifndef _common_h
#define _common_h
 #include
 #include
 #include
 #define uint unsigned int
 #define uchar unsigned char
 #define ulong unsigned long
 //set RF401 into transmit mode; RF module is default receive mode
 #define TRANSMIT
 #define SUCCESS 0xaa
 #define FAILURE 0x55
 #define YES 0xaa
 #define NO 0x55
 #define LED PORT2_5
 #define TXD PORT2_6
 #define RXD PORT2_7
 //#define TXD DIN
 //#define RXD DOUT
 sbit DOUT = P1^0;
 sbit DIN = P1^1;
 sbit RFCS = P3^3;
 sbit PWR_UP = P3^4;
 sbit TXEN = P3^5;
 sbit PORT2_5 = P2^5;
 sbit PORT2_6 = P2^6;
 sbit PORT2_7 = P2^7;
 extern uchar COMFlag;
 extern uint delay;
 extern uchar RecBuf[3];
 extern void InitUART_T1(void);
 //extern void InitUART_T2(void);
 extern void SendUART(uchar DataSend);
 //extern uchar RecUART(void);
 extern void extendUARTsend(uchar DataToSend);
 extern uchar extendUARTreceive(void);
 //extern uchar RFtransceive(uchar RFdata);
评论(9)
发评论
29495282753150 2013-05-24
0 回复 举报
谢谢谢谢谢谢谢谢谢谢谢谢谢谢谢谢 收起回复
togosee 2013-04-30
0 回复 举报
先谢了 收起回复
全部评论
下载排行榜
全部9条评论
