MMA7260QT,pdf(1.5g - 6g Three Axis Low-g Micromachined )
消耗积分:0 | 格式:pdf | 大小:195 KB | 2011-05-12
分享资料个
The MMA7260QT low cost capacitive micromachined accelerometerfeatures signal conditioning, a 1-pole low pass filter, temperaturecompensation and g-Select which allows for the selection among 4sensitivities. Zero-g offset full scale span and filter cut-off are factory set andrequire no external devices. Includes a Sleep Mode that makes it ideal forhandheld battery powered electronics.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
