Abstract: A laser module designer can use a fixed resistor, mechanical pot, digital pot, or a digital-to-analogconverter (DAC) to control the laser driver's modulation and bias currents. The advantages of a programmablemethod (POT or DAC) are that the manufacturing process can be automated and digital control can be applied(e.g., to compensate for temperature). Using POTs can be a more simple approach than a DAC. There can be aslight cost advantage to using a POT, but this is usually not significant relative to other pieces of the design.Using a DAC can offer advantages, including improved linearity (translating to ease of software implementationand ability to hit the required accuracy), increased board density, a wider range of resolutions, a betteroptimization range, ease of use with a negative voltage laser driver, and unit-to-unit consistency
