提出一种可扩展的数据清理软件平台,该软件平台具有开放的规则库和算法库,规则库用来存放清理规则,算法库用来存放清理算法,算法库中包含多种算法,并可对其扩展;通过在规则库中定义清理规则以及从算法库中选择合适的清理算法,可使该软件平台适用于不同的数据源,从而使其具有较强的通用性和适应性;通过多种算法的清理,提高了数据清理的综合效果。最后,通过实例验证了该平台的效果及可行性。
An extensible data cleaning software platform is proposed, which has open rules library and algorithms library. Rules library is used to store rules and algorithms library is used to store algorithms. Algorithms library has many algorithms and can be extended. Through defining rules in rules library and choosing proper cleaning algorithms from algorithms library, the software platform can be used to various data sources, which makes it universal and adaptive. The synthetic result is improved through data cleaning with many algorithms. Finally, the effect and feasibility of this extensible data cleaning software platform is proved through an example.
