CD4014.pdf
消耗积分:5 | 格式:rar | 大小:133 | 2008-04-02
分享资料个
The CD4014BC is an 8-stage parallel input/serial output
shift register. A parallel/serial control input enables individual
JAM inputs to each of 8 stages. Q outputs are available
from the sixth, seventh and eighth stages. All outputs have
equal source and sink current capabilities and conform to
standard “B” series output drive.
When the parallel/serial control input is in the logical “0”
state, data is serially shifted into the register synchronously
with the positive transition of the clock. When the parallel/
serial control input is in the logical “1” state, data is jammed
into each stage of the register synchronously with the positive
All inputs are protected against static discharge with diodes
to VDD and VSS.
Features
 Wide supply voltage range: 3.0V to 15V
 High noise immunity: 0.45 VDD (typ.)
 Low power TTL compatibility: Fan out of 2 driving 74L
or 1 driving 74LS
 5V–10V–15V parametric ratings
 Symmetrical output characteristics
 Maximum input leakage:
1 μA at 15V over full temperature range
评论(0)
发评论
下载排行榜
