The CD4043BC are quad cross-couple 3-STATE CMOS NOR latches, and the CD4044BC are quad cross-couple 3- STATE CMOS NAND latches. Each latch has a separate Q output and individual SET and RESET inputs. There is a common 3-STATE ENABLE input for all four latches. A logic “1” on the ENABLE input connects the latch states to the Q outputs. A logic “0” on the ENABLE input disconnects the latch states from the Q outputs resulting in an open circuit condition on the Q output. The 3-STATE feature allows common bussing of the outputs. Features Wide supply voltage range: 3V to 15V Low power: 100 nW (typ.) High noise immunity: 0.45 VDD (typ.) Separate SET and RESET inputs for each latch NOR and NAND configuration 3-STATE output with common output enable Applications • Multiple bus storage • Strobed register • Four bits of independent storage with output enable • General digital logic
