这是 输出电压电流均可调的高效DC电源:本作品是基于开关电源基本拓扑之一的正激拓扑设计而成的输出小电压,大电流DC-DC开关稳压电源,通过电压反馈环节对主电路的输出进行稳压,本
文所设计的开关电源输入为DC41-57开关频率为75kHz,实现输出电压0-30V可调,恒流限制0-3A可调。单管正激变换器具有外围电路简单,效率高,抗过载能力强,输入与输出隔离等优点,适合低压、中小功率的电能变换,恒压过程采用OP07作为比较器,改变基准电压,从而实现输出电压可调,原副边用光耦隔离,恒流部分也采用比较器,但是电流采样采的是负压,这样只调节电位器就可改变OP07输入端的电压大小,从而调节恒流限制。
关键字:
开关电源 同步整流 辅助电源 单片机显示
Abstract:
This work is based on switch power supply of basic topology of shock topology designed,Output small voltage, large current DC-DC switching power supply,,Through the voltage feedback part of main circuit voltage output,Due to the circuit diodes relative to the output voltage of the pressure drop is bigger,So to output voltage have larger effects, in order to get a higher efficiency, the synchronous rectifier technology of synchronous rectifier since drive technology, circuit and over current protection function.
Key Word:
Switching power supply Synchronous rectifier auxiliary power supply micro-controller shows
