The MAX98096 is a full-featured high performance audiohub with low power consumption and advanced signalprocessing, making it ideal for a wide range of portableapplications.
Three differential analog microphone inputs and four 1-bitdigital microphone inputs accept audio from main, accessory,and background microphones. Analog line inputsaccept four single-ended or two differential audio signals.
Three digital audio interfaces supports standard PCMformats such as I2S, left justified, and TDM. Threeintegrated sample rate converters and highly configurablesignal routing enable a wide range of use cases.
The FlexSoundK audio processor provides low-poweradvanced signal processing, including equalization,dynamic range compression, speaker protection, microphonenoise suppression during wideband calls, acousticecho cancellation, and ambient aware outputs.
