基于AVR单片机的SPWM变频调速控制策略SPWM Vari
消耗积分:10 | 格式:rar | 大小:127 | 2009-05-31
韩刚龙
分享资料个
重点讨论了一种新型单片机—AVR高速嵌入式单片机在交流变频调速中的应用,并给出了软硬件设计方法,同时利用等效面积法生成SPWM脉冲序列,较好的解决了控制精度和实时控制的要求,理论分析和仿真实验证明该方法可行。
关键字:AVR单片机; SPWM波; 等效面积法; 变频调速
Abstract: This paper main discusses the application of AVR--a new type of high-speed embedded micro-controller in the field of AC variable frequency speed regulation (VFSR) system, the designed method of hardware and software were given. The SPWM signal generated by Area Equivalent Principle solve the demands of control accuracy and real-time control. It was proved by analysis and simulative experiment that the proposed method is effective.
Keywords: AVR micro-controller;SPWM wave;Area Equivalent Principle;Variable Frequency Speed Regulation
评论(1)
发评论
忽然飞 2011-04-18
0 回复 举报
收起回复
下载排行榜
全部1条评论
