Nios II软件开发人员手册中的缓存和紧耦合存储器部分
消耗积分:0 | 格式:rar | 大小:391.0 KB | 2012-10-17
Kelly Yang
分享资料个
        Nios II 软件开发人员手册中的缓存和紧耦合存储器部分
Nios® II embedded processor cores can contain instruction and data caches. This
chapter discusses cache-related issues that you need to consider to guarantee that
your program executes correctly on the Nios II processor. Fortunately, most software
based on the Nios II hardware abstraction layer (HAL) works correctly without any
special accommodations for caches. However, some software must manage the cache
directly. For code that needs direct control over the cache, the Nios II architecture
provides facilities to perform the following actions:
评论(0)
发评论
下载排行榜
