模糊恒压供水系统的设计Design of fuzzy Sta
消耗积分:5 | 格式:rar | 大小:152 | 2009-06-03
贾伟刚
分享资料个
本文提出了一种基于模糊控制理论的恒压供水系统,设计出自调整因子控制器,实现了恒压供水,克服了传统PID控制设计中的参数调整困难的问题。介绍了系统的组成及功能,并对系统进行了仿真分析。结果表明,模糊恒压供水系统具有更好的恒压效果。
关键词: 模糊控制变频器 恒压供水
Abstract:This paper put forward a kind of stable pressure water supplying system based on fuzzy control theory ,and designs a fuzzy controller of adjusting the factor by oneself ,which solves the problem that the parameter is difficult to adjust in the course of the traditional PID control. This scheme achieves the water supply with constant pressure .It introduces the configuration and function of the system, and gives a simulation analysis to the system.The results prove that the water supply system based on fuzzy control is better to make the water pressure constant.
Key words:Fuzzy Control Variable frequency drives Supply water under stable pressure
评论(0)
发评论
下载排行榜
