If any device tests an analog designer’s ingenuity, it is an isolation amplifier. Its job is to pass precise analog signals— safely and without degradation—between two points that may differ by hundreds, even thousands, of volts. Even though the high voltage may be damaging and noisy, it is often there by design, and sometimes because of a fault in the system.
