用一个增强型的MOS场效应管对AD9850 进行电压控制或对
消耗积分:10 | 格式:rar | 大小:34 | 2009-06-06
笑过就走
分享资料个
This application note will offer a method to voltage control
or amplitude modulate the output current of the
AD9850 DDS using an enhancement mode MOSFET to
replace the fixed RSET resistor; and a broadband RF
transformer to combine the DDS DAC outputs to produce
a symmetrical AM modulation envelope. Modulation
with reasonable linearity is possible at rates
exceeding 50 kHz. The AD9850 DDS output current
(20 mA maximum) is normally set with a fixed resistor
from the RSET (Pin 12) input to ground. The DAC outputs
are unipolar and complementary (180 degrees out of
phase) of each other.
评论(0)
发评论
下载排行榜
