本文研究了一种基于TMS320C5402 芯片的数字图像处理硬件系统,并使用VB 进行 可视化的处理。在该图像处理系统中,利用DSP 上的键盘模块将各种图像处理方法结合起来,利用DSP 串口和PC 机进行图像数据的传输,并且利用VB 显示处理前后的图像。该系统的设计与实现,为以后进行基于DSP 的数字图像处理独立系统的设计提供了一种新思路。 关键词:数字信号处理;TMS320VC5402 芯片;图像处理;Visual Basic Research and Implementation of New Image Processing System Based on DSP Xing Juanjuan Liu Quan (School of Information Engineering Wuhan University of Technology, Hubei Wuhan 430070) Abstract:Digital image processing hardware system based on the TMS320C5402 chip is mainly researched by this article, and VB is used to carry on the visible processing. In this system, each image processing method is unified in together by using the keyboard module, the preprocess and processed image Data were transported around string mouth to PC machine, therefore the preprocessing and processed image are showed by VB. Thus in the system, one kind of new mentality has been provided for later digital image processing independent system design based on the DSP. Keywords:digital signal processing; TMS320VC5402 chip; image processing; Visual Basic
