MAX77271数据规格书
消耗积分:0 | 格式:pdf | 大小:1.85 MB | 2013-04-03
分享资料个
The MAX77271 step-down converter is optimized forpowering the power amplifier (PA) in multistandard handsetssuch as LTE, WCDMA, TD-SCDMA, GSM, andEDGE. The device integrates a high-efficiency PWM stepdownconverter for medium- and low-power transmissionwith an 85mΩ (typ) low dropout (LDO) bypass regulator,in parallel with the step-down converter, enabling highpowertransmission.
评论(0)
发评论
下载排行榜
