如何用Cypress的 HOTLink(TM)器件替换TAX
消耗积分:5 | 格式:rar | 大小:225 | 2009-06-15
刘满贵
分享资料个
The HOTLink family of devices transfers data from point to
point over high-speed serial links at 160 to 330 Mbits/second
(Figure 1). The CY7B923 Transmitter (Figure 2) takes an 8-bit
parallel data stream and encodes it using the Fibre Channel
compliant and ESCON™-compliant 8B/10B code. This code
maps all 8-bit data characters into a 10-bit transmission code
that insures the transmission signal contains suitable transitions
for recovery by the receiving device. The transmitter
takes this 10-bit data word and converts it to a serial
bit-stream and transmits it at 10 times the byte rate over a
serial transmission link.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
