一种长寿高效Boost超级电容掉电保持后备电源
消耗积分:5 | 格式:rar | 大小:158 | 2009-06-19
分享资料个
本文设计了一种掉电后备电源,采用超级电容作为储能元件可长期浮充,大电流放电,提高了使用寿命;采用升压型拓扑,优化了超级电容容量配置,可在5V@5A 条件下,持续工作10s,并在电容因欠压停止工作时,可迅速关断输出,输出电压单调下降,不产生振荡,满足了大多数设备的需求。
关键词:升压电路,超级电容,掉电保持,后备电源
Abstract: A long lifetime and high effiency power supply for uninterrupted output based on supercapacitor is proposed in this paper. The operating life has been improved by using supercapcitor as maintaining power and capacitance can be optimized by boost topology. The operate time of the power supply is about 10s under the condition 5V@5A. The output voltage can be turned off rapidly and monotonically decreasing when the capacitor undervoltage. It can service most of requirements.
Keyword: boost,supercapacitor,uninterrupted output,back power supply
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
