HMC100 型磁阻式传感器及应用
消耗积分:10 | 格式:rar | 大小:136 | 2009-06-25
李敏
分享资料个
介绍了HMC1001 型磁阻传感器工作的原理,阐述了它在弱磁检测中的地位,设计了在标准线圈中心磁场测量中单片机最小应用系统,给出了测试结果。
关键词: 磁阻式传感器; 线圈; 桥; 弱磁检测
Abstract : Working principle of magnetoresistive sensor is introduced and its statue in weak magnetic field de2 tecting is discussed. A single chip processor’minimal application system in measuring center magnetic field of a standard coil is designed ,the measuring result is given and the common analysis is made.
Key words : magnetoresistive sensor ; coil ; bridge ; weak magnetics detect
评论(0)
发评论
下载排行榜
