Now you can design an optimum LED power supply solution in less than a minute, without the need of a hardware prototype, at no expense. The industry’s most advanced and complete fl yback circuit design tool—Power Supply WebDesigner—has been expanded to include Fairchild’s leading LED drivers. Whether you are a power expert or not, you can specify, simulate and analyze your design faster and easier than ever before. And it is the industry’s fi rst LED online tool that helps design EMI fi lters and predicts PF and THD.
