用于83C751和83C752微控制器串行通信程序驱动的的例
消耗积分:3 | 格式:rar | 大小:23 | 2009-06-27
分享资料个
The need often arises to make use of a serial port in connection with a microcontroller that
does not have a hardware UART on-chip. Aside from the obvious cases where the
microcontroller application intrinsically requires RS-232 communications to achieve its purpose, a serial output may often be a simple and convenient method of providing
detailed diagnostic information to the outside world while using only a single I/O port pin. In
many cases, the solution may be to implement the UART function in software.
The routines included here demonstrate a method to add such a function to a microcontroller without the benefit of a hardware UART.
评论(0)
发评论
下载排行榜
