Z-Wave UPnP Bridge application provides the following features: • When the BC is configured as a primary controller or an inclusion controller it is possible to add and remove nodes • It is possible to add and remove virtual slave nodes using other controller configured as either primary controller or inclusion controller. Up to 128 virtual slave nodes can be added to the BC. • When the BC if configured as a primary controller or an inclusion controller it is possible to add and remove virtual slave nodes without involving other controller. Up to 128 virtual slave nodes can be added to the BC. • Sending BASIC SET ON/OFF and GET commands to Z-Wave nodes in the network • Bridging a Z-Wave Switch node to a UPnP network as a BinaryLight device • Bridging an AV Renderer device to a Z-Wave network as a Z-Wave Switch node • When the BC is configured as a secondary controller it can act as a SUC. • Full controller replication support.
