• Active, single-stage PFC controller provides unity powerfactor& low THD (< 5%) • Low parts count for low system cost and small size • Over 90% efficiency possible • Primary-side control eliminates opto-coupler and secondary-side reference • No external loop compensation required • Active voltage positioning compensates cable IR drop • Primary-side power for constant current operation • Fast transient response • Digital control enables simple design • Critical DCM operation (valley-mode switching) minimizes EMI and improves system efficiency • Blue AngelTM and Energy Star® compliant • Built-in start-up signal to drive active start-up circuit • 20μA typical start-up current • Built-in gate drive with ±1A peak output current • Built-in soft-start • Built-in cycle-by-cycle short-circuit protection
