If you have data security concerns, this document helps you to sanitize or remove memory devices from the listed products。These products have data storage (memory) devices and data output devices (USB ports)。 These instructions tell you how to clear or sanitize the memory devices,and also tell you how to declassify an instrument that is not functioning。Instrument code and calibration settings reside in nonvolatile flash memory。Instrument setups and reference waveforms may also be stored in flash memory or on USB drives connected to the instrument。
