彩屏2.4寸真彩液晶资料(含触摸)
消耗积分:1 | 格式:zip | 大小:10518KB | 2014-08-16
River
分享资料个
2.4寸真彩液晶资料(含触摸)里包含一系列该彩屏资料介绍及显示应用程序,还包含用于提取彩屏图形、文字显示数据的Img2Lcd软件。
  The ADS7843 is a 12-bit sampling Analog-to-Digital Con-verter (ADC) with a synchronous serial interface and low on-resistance switches for driving touch screens. Typical power dissipation is 750µ W at a 125kHz throughput rate and a +2.7V supply. The reference voltage (VREF) can be varied between 1V and +VCC, providing a corresponding input voltage range of 0V to VREF. The device includes a shutdown mode which reduces typical power dissipation to under 0.5µ W. The ADS7843 is specified down to 2.7V operation.
  Low power, high speed, and onboard switches make the ADS7843 ideal for battery-operated systems such as per-sonal digital assistants with resistive touch screens and other portable equipment. The ADS7843 is available in an SSOP-16 package and is specified over the –40° C to +85° C temperature range.
  US Patent No. 6246394
评论(0)
发评论
下载排行榜
