Bluettoothlowenergyswdevelopguide
消耗积分:10 | 格式:pdf | 大小:2271KB | 2014-10-04
davidyang1983
分享资料个
蓝牙4.0软件开发
  Single-Device: The controller, host, profiles, and application are all implemented on the CC2540/41 as a true single chip solution. This is the simplest and most common configuration when using the CC2540/41. This is the configuration that most of our sample projects use. It is most cost effective and provides the lowest-power performance. The SampleBLEPeripheral and SimpleBLECentral projects are examples of applications built using the single-device configuration. More information on these projects can be found in section 4.
评论(0)
发评论
下载排行榜
