The bq24296 and bq24297 are highly-integrated switch-mode battery charge management and system power path management device for 1 cell Li-Ion and Li-polymer battery in a wide range of smartphone and tablet applications。 Its low impedance power path optimizes switch-mode operation efficiency, reduces battery charging time and extends battery life during discharging phase。The I2C serial interface with charging and system settings makes the device a truly flexible solution。
