RF430CL330H Target Board用户指南
消耗积分:1 | 格式:pdf | 大小:404KB | 2015-10-22
谷琦
分享资料个
As shipped, the RF430CL330HTB hardware is configured for I2C mode (CS pin = 0, pull up resistors on SDA/SCL) with address 0x28(E0, E1, E2 = 0). The board must be connected to a host controller in order to set up the NDEF message and properly set registers. In this document, communication with the MSPEXP430FR5739 experimenter’s board is discussed, but the connections will be the same when different host controllers are implemented.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
