atmel-ATA5551芯片的介绍
消耗积分:10 | 格式:pdf | 大小:1277KB | 2015-12-02
andy1840
分享资料个
The Atmel® ATA5551M-PPMY is a completely programmable R/W transponder which implements all important functions for identification systems, including anti-collision (e.g., 10 transponders in < 500ms depending on the application). It allows the contactless reading and writing of data which are transmitted bi-directionally between a read/write base station and the transponder. It is a plastic-packaged device which accommodates the IDIC e5551 and also the antenna realized as an LC-circuit.
评论(0)
发评论
下载排行榜
