风力发电整流器控制策略的研究
消耗积分:5 | 格式:rar | 大小:208 | 2009-08-14
胡秋阳
分享资料个
针对直驱风力发电系统的特性,并与传统的交—直—交系统作比较,提出了采用脉宽
调制(PWM)方法的一种新型整流器。本文对PWM 整流器的原理进行了介绍,通过电压矢量跟踪控制,实现了机侧的整流,最后得出了仿真结果,验证了PWM 整流器取代传统交-直-交系统的可行性。
关键词:风力发电; 整流器; PWM; 功率因数
Abstract:In view of the characters of the direct-drive wind power system,and compared to the AC-DC-AC in the regulation, a novel controllable-PWM rectifier had been proposed. The
principle of the PWM rectifier is introduced in this paper,then realizes commutate in side of the generator by controlling the AC voltage of the generator. Finally, the results of simulation are given. Feasibility of the PWM rectifier is validated in this paper.
Key words:Wind Power; Rectifier; PWM; Power Factor
评论(1)
发评论
2011-05-19
0 回复 举报
好,收藏了。 收起回复
下载排行榜
全部1条评论
