TL082 pdf datasheet
消耗积分:10 | 格式:rar | 大小:444 | 2008-06-13
分享资料个
The TL08_ JFET-input operational amplifier family is designed to offer a wider selection than any previously
developed operational amplifier family. Each of these JFET-input operational amplifiers incorporates
well-matched, high-voltage JFET and bipolar transistors in a monolithic integrated circuit. The devices feature
high slew rates, low input bias and offset currents, and low offset voltage temperature coefficient. Offset
adjustment and external compensation options are available within the TL08_ family.
Device types with a C suffix are characterized for operation from 0°C to 70°C, those with an I suffix are
characterized for operation from –40°C to 85°C, and those with an M suffix are characterized for operation over
the full military temperature range of –55°C to 125°C.
下载资料需要登录,并消耗一定积分。
评论(1)
发评论
lvhsh1726 2012-03-06
0 回复 举报
谢谢楼主 收起回复
下载排行榜
全部1条评论
