AD1990,pdf datasheet (Audio Sw
消耗积分:2 | 格式:rar | 大小:399 | 2009-08-24
分享资料个
The AD1990 is a 2-channel, bridge tied load (BTL), switching audio power amplifier with integrated Σ-Δ modulator. The modulator accepts a single-ended, analog input signal and converts it to a switching waveform to drive speakers directly. A digital, microprocessor-compatible interface provides control of reset, mute, and PGA gain, as well as feedback signals for thermal and overcurrent error conditions. The output stage can operate over a power supply voltages range of 8 V to 12 V. The analog modulator and digital logic operate from a 5 V supply.
评论(0)
发评论
下载排行榜
