OP1177/OP2177/OP4177,pdf datas
消耗积分:5 | 格式:rar | 大小:478 | 2009-08-28
分享资料个
The OPx177 family consists of very high precision, single, dual, and quad amplifiers featuring extremely low offset voltage and drift, low input bias current, low noise, and low power consump-tion. Outputs are stable with capacitive loads of over 1000 pF with no external compensation. Supply current is less than 500 μA per amplifier at 30 V. Internal 500 Ω series resistors protect the inputs, allowing input signal levels several volts beyond either supply without phase reversal.
评论(0)
发评论
下载排行榜
