autocad 2008注册机:Autodesk Autocad Electrical 2008
1. Install Autocad Electrical 2008 (launch setup.exe)
Click on Configure (after accepting license agreement ..)
Select Stand-alone-licence
Click on Custom if you want to select different options
Click on Configuration Complete and then Install
2. Start Autodesk Electrical 2008 and Select Activate the Product
when ask for activation, select Enter an Activation Code
Use as serial : 657-12354321 or 667-98989898 or 667-68686868
Write down the request code.
3. Fire up the xforce keygen and generate an activation code
based on your request code. Continue the registration process
Copy and paste your generated activation code ..
Restart Autocad
4. Enjoy!
