The MAX4999 differential Hi-Speed USB analog multi- plexer features low on-capacitance (CON) switching, making it an ideal solution for the USB server/mass storage market. The MAX4999 is designed for USB 2.0 low-/full-/Hi-Speed applications with capability of sup- porting data rates up to 480Mbps. The MAX4999 is a differential 8:1 multiplexer. The MAX4999 features three digital inputs to control the sig- nal path. Typical applications include switching a USB connector between eight USB hosts and a USB device. An enable input (EN) is provided to disable all channels and place the device into a high-impedance state (standby mode), shutting off the charge pump for mini- mum power consumption. The MAX4999 operates from a +3.0V to +3.6V power- supply voltage and is specified over the -40°C to +85°C extended temperature range. The MAX4999 is available in a 5mm x 5mm, 32-pin TQFN package. Applications Keyboard, Video, Mouse (KVM) Servers/RAID Mass Storage Workstations
