AD5235,pdf datasheet (1024-Pos
消耗积分:5 | 格式:rar | 大小:500 | 2009-09-22
张艳
分享资料个
The AD5235 is a dual-channel, nonvolatile memory,1 digitally controlled potentiometer2 with 1024-step resolution. The device performs the same electronic adjustment function as a mechanical potentiometer with enhanced resolution, solid state reliability, and superior low temperature coefficient performance. The versatile programming of the AD5235 via an SPI®-compatible serial interface allows 16 modes of operation and adjustment including scratchpad programming, memory storing and restoring, increment/decrement, ±6 dB/step log taper adjustment, wiper setting readback, and extra EEMEM1 for user-defined information such as memory data for other components, look-up table, or system identification information.
评论(0)
发评论
下载排行榜
