Micropower Op Amps Work Down t
消耗积分:3 | 格式:rar | 大小:333 | 2009-09-30
分享资料个
Micropower Op Amps Work Down to 1.8V Total Supply,Guaranteed over Temperature:Micropower op amps extend the run time of battery-powered
systems and reduce energy consumption in other
energy limited systems. Nevertheless, battery voltages
change as they are depleted. To maximize a system’s
run time, op amps should operate over a wide enough
supply range to make use of the complete range of battery
voltages, from fully charged to fully depleted. The
new LT®6000 family of 1μA and 13μA op amps operates
on supplies as high as 16V all the way down to 1.8V,guaranteed over temperature.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
