LM9076,pdf datasheet (150mA Ul
消耗积分:3 | 格式:rar | 大小:550 | 2009-10-05
罗星
分享资料个
The LM9076 is a ±3%, 150 mA logic controlled voltage regulator.
The regulator features an active low delayed reset
output flag which can be used to reset a microprocessor system
at turn-ON and in the event that the regulator output
voltage falls below a minimum value. An external capacitor
programs a delay time interval before the reset output pin can
return high.
评论(0)
发评论
下载排行榜
