LP339,pdf datasheet (Ultra-Low
消耗积分:3 | 格式:rar | 大小:555 | 2009-10-08
分享资料个
The LP339 consists of four independent voltage comparators
designed specifically to operate from a single power
supply and draw typically 60 μA of power supply drain current
over a wide range of power supply voltages. Operation
from split supplies is also possible and the ultra-low power
supply drain current is independent of the power supply voltage.
These comparators also feature a common-mode
range which includes ground, even when operated from a
single supply.
评论(0)
发评论
下载排行榜
