DS90CP04,pdf datasheet (1.5 Gb
消耗积分:3 | 格式:rar | 大小:551 | 2009-10-12
分享资料个
DS90CP04 is a 4x4 digital cross-point switch with broadside
input and output pins for efficient board layout. It utilizes Low
Voltage Differential Swing (LVDS) technology for low power,
high-speed operation. Data paths are fully differential from
input to output for low noise. The non-blocking architecture
allows connections of any input to any output or outputs. The
switch matrix consists of four differential 4:1 multiplexes.
Each output channel connects to one of the four inputs common
to all multiplexers.
评论(0)
发评论
下载排行榜
