DS90LV011A,pdf datasheet (3V L
消耗积分:3 | 格式:rar | 大小:557 | 2009-10-13
罗星
分享资料个
The DS90LV011A is a single LVDS driver device optimized
for high data rate and low power applications. The
DS90LV011A is a current mode driver allowing power dissipation
to remain low even at high frequency. In addition, the
short circuit fault current is also minimized. The device is designed
to support data rates in excess of 400Mbps (200MHz)
utilizing Low Voltage Differential Signaling (LVDS) technology.
The device is in a 5-lead small outline transistor package. The
LVDS outputs have been arranged for easy PCB layout. The
differential driver outputs provide low EMI with its typical low
output swing of 350 mV. The DS90LV011A can be paired with
its companion single line receiver, the DS90LV012A, or with
any of National's LVDS receivers, to provide a high-speed
LVDS interface.
评论(0)
发评论
下载排行榜
