平衡的叠层设计(Designing Balanced Pri
消耗积分:0 | 格式:rar | 大小:344 | 2009-10-16
ybw13
分享资料个
平衡的叠层设计(Designing Balanced Printed Circuit Boards):Designers can be tempted to design printed circuit boards (PCBs) with an odd number of layers.
If the additional layer is not needed for routing, why use it? Won’t eliminating the extra layer
minimize board thickness? If the board has one less layer, the cost should be lower...shouldn’t it?
But, on occasion, adding a layer can help reduce costs.
The stackup of layers in the board can be handled in two different ways: core construction or
foil construction (See Figure 1).
评论(0)
发评论
下载排行榜
