/* -- 深圳市安信可科技有限公司 -- */
// 文件名:
// 说明:
// 编写人员:wuzhibiao
// 编写日期:2013年3月15日
// 程序维护:
// 维护记录:
// 免责声明:该程序仅用于学习与交流
// (c) Anxinke Corporation. All rights reserved.
#ifndef _BYTE_DEF_
#define _BYTE_DEF_
#define TX_ADR_WIDTH 5 // 5 bytes TX(RX) address width
#define TX_PLOAD_WIDTH 32 // 32 bytes TX payload
#define READ_REG 0x00 // Define read command to register
#define WRITE_REG 0x20 // Define write command to register
#define RD_RX_PLOAD 0x61 // Define RX payload register address
#define WR_TX_PLOAD 0xA0 // Define TX payload register address
#define FLUSH_TX 0xE1 // Define flush TX register command
#define FLUSH_RX 0xE2 // Define flush RX register command
#define REUSE_TX_PL 0xE3 // Define reuse TX payload register command
#define NOP 0xFF // Define No Operation, might be used to read status register
// SPI(nRF24L01) registers(addresses)
#define CONFIG 0x00 // ‘Config’ register address
#define EN_AA 0x01 // ‘Enable Auto Acknowledgment’ register address
#define EN_RXADDR 0x02 // ‘Enabled RX addresses’ register address
#define SETUP_AW 0x03 // ‘Setup address width’ register address
#define SETUP_RETR 0x04 // ‘Setup Auto. Retrans’ register address
#define RF_CH 0x05 // ‘RF channel’ register address
#define RF_SETUP 0x06 // ‘RF setup’ register address
#define STATUS 0x07 // ‘Status’ register address
#define OBSERVE_TX 0x08 // ‘Observe TX’ register address
#define CD 0x09 // ‘Carrier Detect’ register address
#define RX_ADDR_P0 0x0A // ‘RX address pipe0’ register address
#define RX_ADDR_P1 0x0B // ‘RX address pipe1’ register address
#define RX_ADDR_P2 0x0C // ‘RX address pipe2’ register address
#define RX_ADDR_P3 0x0D // ‘RX address pipe3’ register address
#define RX_ADDR_P4 0x0E // ‘RX address pipe4’ register address
#define RX_ADDR_P5 0x0F // ‘RX address pipe5’ register address
#define TX_ADDR 0x10 // ‘TX address’ register address
#define RX_PW_P0 0x11 // ‘RX payload width, pipe0’ register address
#define RX_PW_P1 0x12 // ‘RX payload width, pipe1’ register address
#define RX_PW_P2 0x13 // ‘RX payload width, pipe2’ register address
#define RX_PW_P3 0x14 // ‘RX payload width, pipe3’ register address
#define RX_PW_P4 0x15 // ‘RX payload width, pipe4’ register address
#define RX_PW_P5 0x16 // ‘RX payload width, pipe5’ register address
#define FIFO_STATUS 0x17 // ‘FIFO Status Register’ register address
#define STA_MARK_RX 0X40
#define STA_MARK_TX 0X20
#define STA_MARK_MX 0X10
#define IRQ P11
#define CE P14
#define CSN P15
#define SCK P12
#define MOSI P13
#define MISO P10
// FUNCTION‘s PROTOTYPES //
void SPI_Init(BYTE Mode); // Init HW or SW SPI
BYTE SPI_RW(BYTE byte); // Single SPI read/write
BYTE SPI_Read(BYTE reg); // Read one byte from nRF24L01
BYTE SPI_RW_Reg(BYTE reg, BYTE byte); // Write one byte to register ’reg‘
BYTE SPI_Write_Buf(BYTE reg, BYTE *pBuf, BYTE bytes); // Writes multiply bytes to one register
BYTE SPI_Read_Buf(BYTE reg, BYTE *pBuf, BYTE bytes); // Read multiply bytes from one register
void NRF24L01_SPI_Init(BYTE Mode); // Init HW or SW SPI
uchar SPI_RW(BYTE byte); // Single SPI read/write
uchar SPI_Read(BYTE reg); // Read one byte from nRF24L01
uchar SPI_RW_Reg(BYTE reg, BYTE byte); // Write one byte to register ’reg‘
uchar SPI_Write_Buf(BYTE reg, BYTE *pBuf, BYTE bytes); // Writes multiply bytes to one register
uchar SPI_Read_Buf(BYTE reg, BYTE *pBuf, BYTE bytes); // Read multiply bytes from one register
void init_nrf24l01_io(void);
void ifnnrf_rx_mode(void);
uchar send_data(uchar *buf);
void receive_mode_init(void);
uchar receive_data(uchar *buf);
void ifnnrf_CLERN_ALL();
#endif
