AP1624,pdf,datasheet (PWM/PFM
消耗积分:3 | 格式:rar | 大小:322 | 2009-10-17
分享资料个
The AP1624 is multi-functional step-up DC/DC
controllers. Large output current is possible using
an externally connected N channel MOSFET, coil,
and diode.
Output voltage (VOUT)is programmable with 1.23V
of standard voltage supply internal, and using
externally connected components, output voltage
(FB) can be set up at will.
With a 300KHz switching frequency, the size of the
external components can be reduced.
Control switches from PFM to PWM during light
loads with the AP1624(PFM/PWM switchable)and
the series is highly efficient from light loads to large
output currents.
评论(0)
发评论
下载排行榜
