ADM8828/ADM8829,datasheet,pdf(
消耗积分:5 | 格式:rar | 大小:554 | 2009-10-23
张国厚
分享资料个
The ADM8828/ADM8829 is a charge-pump voltage inverter
which may be used to generate a negative supply from a positive
input. Input voltages ranging from +1.5 V to +5.5 V can be
inverted into a negative –1.5 V to –5.5 V output supply. This
inverting scheme is ideal for generating a negative rail in single
power-supply systems. Only two small external capacitors are
needed for the charge pump. Output currents up to 25 mA with
greater than 99% efficiency are achievable.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
