这些限制是痛苦的,特别是如果复杂的线性如数据转换器和采样保持电路功能是必要的。尽管存在问题,设计这样的电路通过结合相当大的关注组件常用电路特性。
10kHz V→F Converter Figure 1, an example of this approach, is a complete 1.5V powered 10kHz V→F converter. A 0V to 1V input produces a 25Hz to 10kHz output, with a transfer linearity of 0.35%. Gain drift is 250ppm/°C and current consumption about 205μA.
To understand circuit operation, assume C1’s positive input is slightly below its negative input (C2’s output is low)。
